11 years agoHow to implement DE0 SDRAM as 2-port RAM
I currently use the tiny bit of memory on the FPGA for a computer vision project but it's way too limited. I have a stand-alone SDRAM controller from Altera (partially pasted below) but I need one mo...
11 years agoI have modelsim 10.1c SE installed and a testbench made but I need a SDRAM simulation model. Any idea what the detailed steps are to get one set up in modelsim?
# This reference design requires a vendor simulation model.
# To simulate accesses to SDRAM, you must:
# - Download the vendor model
# - Install the model in the system_sim directory
# - Add the vendor file to the list of files passed to 'vcom' in setup_sim.do
# - Instantiate sdram simulation models and wire them to testbench signals
# - Be aware that you may have to disable some timing checks in the vendor model
# (because this simulation is zero-delay based)
