11 years agoHow to implement DE0 SDRAM as 2-port RAM
I currently use the tiny bit of memory on the FPGA for a computer vision project but it's way too limited. I have a stand-alone SDRAM controller from Altera (partially pasted below) but I need one mo...
11 years ago --- Quote Start --- There are no packets or other data that can be reliably grouped or streamed. There are two different entities requesting to read and write from unpredictable addresses at unpredictable times usually simultaneously. --- Quote End --- But you call them camera and VGA interfaces. I would have thought they would work on frames of data. Based on your comments, the interfaces would not be implemented as Avalon-ST streams, but they do sound like they can be implemented as Avalon-MM master interfaces. --- Quote Start --- So far I've created the QSYS component for the camera. I think I picked bridges and adapters/Avalon ST. It ended up being a memory master though after I set all of the parameters.. I messed up and made all the exports reside under one conduit name but other than that it might work.. I have a feeling I can't just connect the two masters to the SDRAM controller and trust that it will just 'figure' it out. --- Quote End --- Yes, you can. So long as the two masters implement the Avalon-MM protocol correctly, then read and writes should work fine. You would use your simulation to determine if the default arbitration shares are appropriate, or whether you need to change them. --- Quote Start --- There is probably some component that needs to handle that.. It would set priority like you mentioned earlier.. Any idea what component that would be? --- Quote End --- Stop making me repeat myself. If you're not going to read the documentation on Qsys, arbitration, and arbitration shares, then I'll just stop responding to this thread. --- Quote Start --- Maybe a frame buffer? I hope not because I want to be able to store and retrieve all sorts of other data using this SDRAM chip and random times.. --- Quote End --- This is what you need a simulation to determine. If data read pre-fetching or write-posting is appropriate in your design, then a buffer between your devices and the SDRAM might be sufficient. This buffering would be most efficient if your data transfers occur in blocks, but you make it sound like that is not the case. Cheers, Dave
