11 years agoHow to implement DE0 SDRAM as 2-port RAM
I currently use the tiny bit of memory on the FPGA for a computer vision project but it's way too limited. I have a stand-alone SDRAM controller from Altera (partially pasted below) but I need one mo...
11 years ago --- Quote Start --- 1. In the DE0 manual, the size of SDRAM_ADDR is 13bits, [12:0], but the wizard generates a 12 bit vector, [11:0]. Which one is right if the SDRAM size is 8Mb? --- Quote End --- Check the data sheet for the SDRAM. Most board designers are conservative and include "extra" address bits to make the board suitable for loading several device sizes. --- Quote Start --- 2. Do you see anything wrong with the "sdram_controller_wire" block of signals? Like BA or DQM are backwards? --- Quote End --- What do you mean by backwards? The port direction appears correct - the controller drives those signals. --- Quote Start --- sdram_controller_s1: 3. Is chip select just used to enable sdram_controller_s1? 4. What is byte enable for in this instance? 5. Why isn't read_n and write_n one signal instead of two? Does that mean you can write and read at the same time? --- Quote End --- Create a simulation model and use that to answer these questions :) Its likely that chipselect and read_n need to assert for read, and chipselect and write_n need to assert for write. Cheers, Dave
