11 years agoHow to implement DE0 SDRAM as 2-port RAM
I currently use the tiny bit of memory on the FPGA for a computer vision project but it's way too limited. I have a stand-alone SDRAM controller from Altera (partially pasted below) but I need one mo...
11 years agoSeems like I'm making progress.. I have a few questions about entity instance below:
sdram_controller_wire: 1. In the DE0 manual, the size of SDRAM_ADDR is 13bits, [12:0], but the wizard generates a 12 bit vector, [11:0]. Which one is right if the SDRAM size is 8Mb? 2. Do you see anything wrong with the "sdram_controller_wire" block of signals? Like BA or DQM are backwards? sdram_controller_s1: 3. Is chip select just used to enable sdram_controller_s1? 4. What is byte enable for in this instance? 5. Why isn't read_n and write_n one signal instead of two? Does that mean you can write and read at the same time? -- sdram controller
sdram_controller : process(clk50, btn(2))
begin
if btn(2) = '0' then
sdram_controller_s1_address_s <= (others => '0');
elsif rising_edge(clk50) then
if (wren = '0') then
sdram_controller_s1_address_s <= wraddress;
else
sdram_controller_s1_address_s <= rdaddress;
end if;
end if;
end process;
SDRAM_BA_1 <= sdram_controller_wire_ba_s(1);
SDRAM_BA_0 <= sdram_controller_wire_ba_s(0);
SDRAM_UDQM <= sdram_controller_wire_dqm_s(1);
SDRAM_LDQM <= sdram_controller_wire_dqm_s(0);
SDRAM_ADDR <= '0' & sdram_controller_wire_addr_s(11 downto 0);
Inst_sdram : entity work.SDRAM_QSYS port map(
clk_100mhz_clk => sdram_clk_s, --: in std_logic := '0'; clk.clk
reset_reset_n => btn(2), --: in std_logic := '0'; reset.reset_n
sdram_controller_wire_addr => sdram_controller_wire_addr_s, --: out std_logic_vector(11 downto 0); sdram_controller_wire.addr
sdram_controller_wire_ba => sdram_controller_wire_ba_s, --: out std_logic_vector(1 downto 0); .ba
sdram_controller_wire_cas_n => SDRAM_CAS_N, --: out std_logic; .cas_n
sdram_controller_wire_cke => SDRAM_CKE, --: out std_logic; .cke
sdram_controller_wire_cs_n => SDRAM_CS_N, --: out std_logic; .cs_n
sdram_controller_wire_dq => SDRAM_DQ, --: inout std_logic_vector(15 downto 0) := (others => '0'); .dq
sdram_controller_wire_dqm => sdram_controller_wire_dqm_s, --: out std_logic_vector(1 downto 0); .dqm
sdram_controller_wire_ras_n => SDRAM_RAS_N, --: out std_logic; .ras_n
sdram_controller_wire_we_n => SDRAM_WE_N, --: out std_logic; .we_n
sdram_controller_s1_address => sdram_controller_s1_address_s, --: in std_logic_vector(21 downto 0) := (others => '0'); sdram_controller_s1.address
sdram_controller_s1_byteenable_n => "11", --: in std_logic_vector(1 downto 0) := (others => '0'); .byteenable_n
sdram_controller_s1_chipselect => '1', --: in std_logic := '0'; .chipselect
sdram_controller_s1_writedata => wrdata, --: in std_logic_vector(15 downto 0) := (others => '0'); .writedata
sdram_controller_s1_read_n => wren, --: in std_logic := '0'; .read_n
sdram_controller_s1_write_n => not wren, --: in std_logic := '0'; .write_n
sdram_controller_s1_readdata => open, --: out std_logic_vector(15 downto 0); .readdata
sdram_controller_s1_readdatavalid => open, --: out std_logic; .readdatavalid
sdram_controller_s1_waitrequest => open --: out std_logic
