11 years agoHow to implement DE0 SDRAM as 2-port RAM
I currently use the tiny bit of memory on the FPGA for a computer vision project but it's way too limited. I have a stand-alone SDRAM controller from Altera (partially pasted below) but I need one mo...
11 years ago --- Quote Start --- It looks like it will work but I'm still messing with it... --- Quote End --- I haven't tried this with the SDRAM controller, but with the DDR controller, you can have Qsys generate a testbench, and it will include an DDR SDRAM model. For DDR SDRAM, I get Qsys to generate a top-level testbench, and then use that as a template for my own testbench. The piece of code I am typically interested in, is the SDRAM model instance, i.e., the fake SDRAM that the SDRAM controller reads/writes to. I then go back to the Qsys system and add a BFM, or I'd connect to the Avalon-MM slave port you're going to export to your top-level design, and use that to generate Avalon-MM transactions. Cheers, Dave
