14 years agoHow to implement a FIR filter with the ALTSHIFT_TAPS megafunction
Good day, I am trying to implement an FIR that will have 128 taps of 21 bits each tap. I am trying to do this with the ALTSHIFT_TAPS megafunction. However, I am confused with the TAP_DIS...
14 years agoI used alt shift taps for FIR. The minimum distance between taps was 3 and what I did was to run the shift 3 times faster than sample rate thus tap distance was in effect reduced to 1.
