13 years agohow to ENABLE/DISABLE parts of an IP-core depending on the instance parameters??
Hi @all, if have already posted this question in the following thread: http://www.alteraforum.com/forum/showthread.php?t=40155 (post # 3) and i think it is worth starting a new thread for discu...
13 years ago --- Quote Start --- @Dave: Fortunately I have not to simulate the IP-Cores. As I interpret your recommendation, you are using a tcl-file to describe your top-level instance, right? And the top-level consists of several filesets containing VHDL-designs and simulation information. Again these filesets will be modified in the fileset_callback procedure according to the users choice. --- Quote End --- Not quite. I use the Tcl file to *create* the top-level instance.
-- avs_single_port_ram_template.vhd
library ieee;
use ieee.std_logic_1164.all;
entity avs_single_port_ram_template is
port (
-- Reset and clock
clk : in std_logic;
rstN : in std_logic;
-- Avalon Slave Interface
avs_read : in std_logic;
avs_write : in std_logic;
avs_addr : in std_logic_vector(ADDR_WIDTH_MINUS_1_VAL downto 0);
avs_byteen : in std_logic_vector(BYTEEN_WIDTH_MINUS_1_VAL downto 0);
avs_wrdata : in std_logic_vector(DATA_WIDTH_MINUS_1_VAL downto 0);
avs_rddata : out std_logic_vector(DATA_WIDTH_MINUS_1_VAL downto 0);
avs_rdvalid : out std_logic;
avs_wait : out std_logic
end entity;
architecture avs_wrapper of avs_single_port_ram_template is
component avs_single_port_ram is
generic (
ADDR_WIDTH : integer;
BYTEEN_WIDTH : integer;
DATA_WIDTH : integer
port (
clk : in std_logic;
avs_addr : in std_logic_vector( ADDR_WIDTH-1 downto 0);
avs_byteen : in std_logic_vector(BYTEEN_WIDTH-1 downto 0);
avs_wrdata : in std_logic_vector( DATA_WIDTH-1 downto 0);
avs_rddata : out std_logic_vector( DATA_WIDTH-1 downto 0);
end component;
begin
u1: component avs_single_port_ram
generic map (
ADDR_WIDTH => ADDR_WIDTH_VAL,
BYTEEN_WIDTH => BYTEEN_WIDTH_VAL,
DATA_WIDTH => DATA_WIDTH_VAL
port map (
clk => clk,
rstN => rstN,
avs_read => avs_read,
avs_write => avs_write,
avs_addr => avs_addr,
avs_byteen => avs_byteen,
avs_wrdata => avs_wrdata,
avs_rddata => avs_rddata,
avs_rdvalid => avs_rdvalid,
avs_wait => avs_wait
end architecture;
and the Tcl file "fills in the details" using the generate call-back # -----------------------------------------------------------------# Generation# -----------------------------------------------------------------#
proc generate {} {
send_message info "Starting generation of the RAM"
# Output file location and instance name
set outlang
set outdir
set outname
if { == 0} {
send_message info "language = $outlang, file = $outdir/$outname.vhd"
} else {
send_message warning "This component will be generated using VHDL."
# Get the parameter values;
# These parameters require the following settings above:
# - AFFECTS_GENERATION true
# This setting enables the calls to get_parameter_value
# - HDL_PARAMETER false
# This parameter suppresses a check for these generics
# in the top-level generated file. Those generics are
# hidden inside the top-level instance.
set params {
BYTEEN_WIDTH
ADDR_WIDTH
DATA_WIDTH}
foreach param $params {
# Get the parameters from SOPC Builder
set $param
# Print the parameters to the generate console
eval send_message info \"$param = $$param\"
# Create the 'minus 1' versions
set BYTEEN_WIDTH_MINUS_1
set ADDR_WIDTH_MINUS_1
set DATA_WIDTH_MINUS_1
# Instance file generation
# - read in the template file
# - use Tcl string replacement to create an instance
# version of the template
# - write out the template file
# Open the template file
set file "avs_single_port_ram_hw_template.txt"
if {} {
send_message error "open $file failed"
# Read the template into a buffer
set buffer
close $fd
# Replace the entity and architecture strings
set buffer $buffer]
# Replace the generic values (suffixed by _VAL in the template)
set params {
BYTEEN_WIDTH
ADDR_WIDTH
DATA_WIDTH
ADDR_WIDTH_MINUS_1
DATA_WIDTH_MINUS_1}
eval set buffer \ \$buffer\]
# Write the instance file
set file "$outdir/$outname.vhd"
if {} {
puts $fd $buffer
close $fd
# Add the generated file to the project
add_file "$outdir/$outname.vhd" {SYNTHESIS SIMULATION}
I've uploaded the code. I just pulled this out of my code tree, it should work, but if I've missed a file, let me know and I'll upload a working example. Cheers, Dave
