13 years agohow to ENABLE/DISABLE parts of an IP-core depending on the instance parameters??
Hi @all, if have already posted this question in the following thread: http://www.alteraforum.com/forum/showthread.php?t=40155 (post # 3) and i think it is worth starting a new thread for discu...
13 years agoYou can implement what you are after using the generate callback.
Qsys/SOPC builder does not handle boolean and real valued generics in VHDL, and it also did not used to handle VHDL libraries correctly (in the sense that the auto-created components could not be simulated in Modelsim due to missing library statements). To get around these issues I use the generate callback to create my own top-level instance. In your case, you can have two different HDL implementations, and pick up the one the user selects. Cheers, Dave
