15 years agohow to design a low pass digital filter with smallest delay
Hello, All I want to design a digital filter with the cutoff frequency 20Hz. The sampling frequency of my acquiring system is very high, up to 8192 Hz. The important requirement is the de...
15 years ago --- Quote Start --- sure its possible with 81 taps --- Quote End --- Depends on your definition of "possible". It can't implement a cut-off frequency of 20 Hz even if you accept any band ripple or attenuation. If you don't see why, try with a filter tool, e.g. Quartus FIR compiler.
