15 years agohow to design a low pass digital filter with smallest delay
Hello, All I want to design a digital filter with the cutoff frequency 20Hz. The sampling frequency of my acquiring system is very high, up to 8192 Hz. The important requirement is the de...
15 years ago --- Quote Start --- I don't want to use the inverse model of the filter to cancel the delay. --- Quote End --- I assume, you can't cancel the delay even if you want. Group delay is a characteristic parameter of a filter, it can't be changed at will. You get the lowest with a low order Bessel filter. But it depends on your filter characteristic requirements.
