16 years agoHow to constraint clocks from the ASI IP Core?
I am using the ASI Recieve IP Core. As the datasheet(ug_asi.pdf) suggests, I need to constraint three clocks: rx_serial_clk, rx_serial_clk90 and rx_clk135.(Actually rx_serial_clk and rx_serial_clk...
16 years agoI'm using the ASI core in a Cyclone III, try something like this:
derive_pll_clocks -create_base_clocks set rx_clk135 "ASI_RX_PLL_1|altpll_component|auto_generated|pll1|clk[0]" set rx_serial_clk "ASI_RX_PLL_1|altpll_component|auto_generated|pll1|clk[1]" set rx_serial_clk_90 "ASI_RX_PLL_1|altpll_component|auto_generated|pll1|clk[2]" set_max_delay -from $rx_serial_clk -to $rx_clk135 4.430; set_min_delay -from $rx_serial_clk -to $rx_clk135 0.000; # added this to make sure the sample_a/b/c/d registers were not located in the wrong place. :-) set_max_delay -from ASI_RX_Pi [*] -to * 4.50; Don't forget to add the location constraints for the sample_a, sample_b, sample_c, and sample_d registers too.
