16 years agoHow to constraint clocks from the ASI IP Core?
I am using the ASI Recieve IP Core. As the datasheet(ug_asi.pdf) suggests, I need to constraint three clocks: rx_serial_clk, rx_serial_clk90 and rx_clk135.(Actually rx_serial_clk and rx_serial_clk...
16 years agoYou can try "get_registers" or "get_pins"?
