15 years agoHow to constrain tse on cyclone III board
Hi all, I have a cyclone III board with Marvell 88E1111 RGMII PHY. I am trying to send packet from host to FPGA using RGMII receiving interface (I don't need the transmit function so the transm...
15 years agoAfter carefully examine the data from RGMII using signalTap, I found that the data before preamble is "ffff" instead of "ff" (considering DDR). This is 16bits extra data, and I am wondering is it related with IP Payload Alignment to align packet header to 32-bit boundaries?
If the answer is yes, how should I remove this extra data? I tried to select "Align packet headers to 32-bit boundaries" option when I was generating tse MAC in SOPC builder and also tried set bit 25 of "rx_cmd_stat" register to 0 and 1, but no matter what, MAC still indicates this is a frame received with alignment error and then discard it. I am using Windows XP "ping" command to generate the packet, so does this command generate the extra "ffff" or the Marvell PHY generate "ffff"?
