16 years agoHow to Connect to SOPC Avalong Bus from outside of SOPC
I'm using the SDRAM with Nios and SOPC, but I also need to write to the SDRAM via logic that is outside the SOPC. How is this typically done? I'm assuming I would need to create a peripheral ...
16 years agoIt should be in the controller ptf file. Also it looks like the DDR controllers use 32 now. To find the value I normally open the sopc file in a file editor and search for the slave port.
