11 years agoHow to configure MSI interrupt
Hi, For PCIe Hard IP, how to setup/configure MSI interrupts? For example, I have DMA read and DMA write transactions, setting up through descriptors. At the last PTR, it sends MSI interrupts....
11 years agoFor the Av-ST version at least, the message ID in the ISR routine (I'm assuming you are using KMDF/Windows) is directly related to which number the MSI is. When an MSI is send through the streaming core you also have to configure which number it is by a separate input.
As for the Av-MM DMA version, I am not sure how this is done (or if it is possible).
