11 years agoHow to configure MSI interrupt
Hi, For PCIe Hard IP, how to setup/configure MSI interrupts? For example, I have DMA read and DMA write transactions, setting up through descriptors. At the last PTR, it sends MSI interrupts....
11 years agoThank you for your reply.
There are up to 16 lines of interrupt signals OR-ed into a single MSI interrupt. How these IRQ lines are associated with particular PCIe link/function or operations? e.g. Is there a way to associated DMA read completion to line A, and DMA write completion to line B? The message ID in the ISR routine represents something or it is just a dummy parameter?
