12 years agoHow to check Gain with ModelSim-ASE (FIR Compiler)
Hello everybody, I try to FIR Compiler simulation. I want to know how to calculate Gain from simulation result. I think that " Gain = 10 log (Vin / Vout)^2 ", but Fir Compiler's input da...
12 years agoHi Dave,
Thank you very much for reply. Sorry, I don't have requirements because I use FIR Filter for understanding how to use FIR compiler IP. How about following requestments? 1. LPF 2. cut off frequency : 1.25MHz 3. input 8bit 4. ADC sampling frequency : 3MHz ( ttp://www.ti.com/lit/ds/symlink/adc1173.pdf Does it need enough bigger than cut off frequency?) 5. Pass-band ripple requirement : 0.3dB 6. Stop-band rejection requirement : 40dB Thanks, jas39
