12 years agoHow to check Gain with ModelSim-ASE (FIR Compiler)
Hello everybody, I try to FIR Compiler simulation. I want to know how to calculate Gain from simulation result. I think that " Gain = 10 log (Vin / Vout)^2 ", but Fir Compiler's input da...
12 years agoHi Dave,
Thank you for reply, I understood "I should reduce taps, and reduce bit-growth", "I should edit coefficients, and reduce sun(abs(h[n]))", and so on. Excuse me, may I addition question? If I designed to maximize the dynamic range, how to calucurate gain? I think that input.txt and output.txt is voltage. example input bits : 8bit input data : 100 ~ -100 bit-growth : 6.6 (log2(100)) output bits : 15bit output data at one point : 25500 (sum of 100 0xFF values) The following calculations correct? Gain = 10 log (Vin / Vout)^2 = 10 log (100 / 25500)^2 = 48dB It seems to be amplified. or I should convert out put max range into input data range (100 ~ -100) by user logic? Thanks, jas39
