14 years agoHow I can read video frame in niosII for image processing
Hi All, How I can read video frame in niosII for image processing? I use the following IP & VIP: cpu sram altpll timer sysid jtag_uart sdram Clocked Video Input Color Pla...
14 years agoHi,
It depend on the kind of processing but for full image transformation with simple operations, a streaming module would be more efficient. Yet for NiosII access to frame: You should know when the image buffer is located in memory. Link the AvalonMM data bus of NiosII to that memory. Use IORD and IOWR to change the content. To send it over the ethernet, you can use sockets base on the InterNiche stack for example, you need to look to samples using it.
