12 years agoHow do Matrix Transpose (corner turn) with SGDMA ?
Hi all, I want use SGDMA to do matrix transpose. Matrix dimension is 512x16. It is possible? At first, by using Stream-to-Memory to store 16 stacked of data vertically from data stream (data le...
12 years agoYour question lacks some vital information:
I read that the incoming data are 512 V * 16 H. How many bits is each data-word? What is the incoming speed in MW/s? What is the required outgoing speed in MW/s What type of memory do you have?How many bits wide? How fast? What other components are accessing this memory? With what bandwidth requirements?
