13 years agoHow can i use the tse ip core with qsys?
hi, I am a new to qsys and nios and I am able to use the tse ip core to communicate with pc using TCP/IP.But i don't know how to do implement my design target.So, could anyone give me some tip...
13 years agoYes it is OK for both NIOS and SGDMA to access the same memory (DDR2 or otherwise).
Yes it is OK to use different types of memory (SRAM, or flash) instead-of or in-addition-to DDR2. Regarding flash, obviously you could not use that for SGDMA/TSE packet storage (well, you could but it would be so limited usefulness it is not worth discussing).
