13 years agoHow can i use the tse ip core with qsys?
hi, I am a new to qsys and nios and I am able to use the tse ip core to communicate with pc using TCP/IP.But i don't know how to do implement my design target.So, could anyone give me some tip...
13 years ago --- Quote Start --- Yes, TCP/IP is often done in software. NicheStack is one solution, and has the benefit that it is included with the Altera environment and the integration work is already done for you. Some of the other possibilities are listed here: http://www.altera.com/devices/processor/nios2/tools/embed-partners/ni2-network-stack.html --- Quote End --- I'm much obliged to you for hleping me.I'm confused about the component library provide by Qsys,i don't know when should i use the JTAG_UART,System ID Peripheral and On-Chip Memory.Whether can it work properly when i just use the tse ip core and niosii processer without anything else?Could you give me some tips about how to coustom my own ehernet qsys system?I really appreciate all of your help!
