15 years agohow can i use SDI IPcore in EP3C5E144
HI,evrybody.I'm newer in here.I want to use EP3C5E144 generate sdi test parttern.Can you give me an example?
15 years agoFirstly, generate a stream using test pattern generator(8 or 10bit stream + 27MHz clk + data valid signal), then use SDI megacore to generate SDI output. It requires 27MHz input clock (You must use the same as for the video parallel stream mentioned before) + 270MHz reference clock from the PLL of the 27MHz (ratio 10/1), if You're trying to generate SD SDI.
