18 years agoHow Can I set up DMA operation with my own PC software application?
Hi All: I want to re-use the pcie_highperformancedesign example provided by the Arria GX Development Kit. Now I am confused with the PC software application altpcie_demo.exe. :confused: I a...
15 years agoBrett,
You are right. The first step(writing 0xffff to DW0)will reset the DMA and last step(writing to DW3) will start the DMA. But i am seeing some issue with write_dma read address to end point memory in RTL. The address goes beyond the length specified in descriptor. It looks ok with read DMA. Has anybody observed same and tested at higher level ?. Thanks Sharan
