18 years agoHow Can I set up DMA operation with my own PC software application?
Hi All: I want to re-use the pcie_highperformancedesign example provided by the Arria GX Development Kit. Now I am confused with the PC software application altpcie_demo.exe. :confused: I a...
18 years agoThat .sof should be okay. I'm not a software guy so I'm not sure what could be wrong. Do you see the device with PCI bus scanning software? On Linux systems I have seen something called "lspci" that does that. If you are not seeing the device with that then the board is probably not configuring or something. But if the san finds it, then there is something wrong in the software at your end.
