16 years agoHow can I mux an AvalonMM Bus (VIP_VFR -> 2x SDRAM)
My question is: How I can mux an AvalonMM bus from the FrameReader to access two different SDRAM-modules? The idea I had was to create one bit I connect to a custom-module. By this bit I would ...
16 years agoI agree with Kevin. Any reason why you can't just connect the master to both memories? If not, a switch would be really easy to make. You just need to make sure it's got all the same required signals and you're set.
Jake
