16 years agoHow can I mux an AvalonMM Bus (VIP_VFR -> 2x SDRAM)
My question is: How I can mux an AvalonMM bus from the FrameReader to access two different SDRAM-modules? The idea I had was to create one bit I connect to a custom-module. By this bit I would ...
16 years agoIs there a reason why you cannot just connect the frame reader directly to both SDRAM modules?
When you want to switch between them, you can reset the base address the frame reader uses via it's slave port.
