18 years agoHow can I get data from Altera Triple Speed Ethernet (TSE) MAC through Avalon bus?
I know the simple answer will be use NisoII... But in my situation is ..I cannot use NisoII or any other soft/hard core processor (actually is..I am not able to use any asm/c ..whatever comput...
16 years agoHi,
first of all, i'm sorry for posting in a old topic, but i've don't found other posts or places wich can help me and show me a way to start using TSE. I'm a bit confuse about this: --- Quote Start --- b.control path There is another register read/write interface for the MAC configuration as a control plane called AValon-Memory Map interface, but it is no more than a interface consist of address, write, read, readdata, writedata signal(you don't even need to read the spec). You just need to write a sequential state machine to setup all the configuration register one by one so that the MAC work in a way you expect in the beginning, it is very simple. --- Quote End --- does it mean that i must to configure all 256 registers :(?? and, the addres bus is 8 bits width, and the adress are 32 bits width. so, how can i access some address? :confused: Thanks and happy new year, everyone :D Regards, Nathan.
