18 years agoHow can I get data from Altera Triple Speed Ethernet (TSE) MAC through Avalon bus?
I know the simple answer will be use NisoII... But in my situation is ..I cannot use NisoII or any other soft/hard core processor (actually is..I am not able to use any asm/c ..whatever comput...
17 years agoHi..
can anyone tell me whether TSE MAC supports TCP/IP..? regards.. --- Quote Start --- I know the simple answer will be use NisoII... But in my situation is ..I cannot use NisoII or any other soft/hard core processor (actually is..I am not able to use any asm/c ..whatever computer programing language). I would want to know anyone try to build a FSM to "talk" with the Avalon bus before? What should I do/understand first for build a FSM to work as Master in Avalon bus? My project require to receive packet and put them into memory and then I have another logic to read from the memory. The data flow is that Ethernet --> PHY(chip) --> TSE MAC IP --> Avalon bus --> memory -- >DDR2 controller ->DDR2 memory. What I have now: 1. PCI Express Development Kit, Stratix II GX Edition (http:// www.altera.com/products/devkits/altera/kit-pciexpress_s2gx.html (http://www.altera.com/products/devkits/altera/kit-pciexpress_s2gx.html)) 2. DDR2 controller demo (non Avalon Bus), (it is work on the PCI Express Development Kit) 3. TSE MAC IP (I did not try it..because all the demo are using NiosII) --- Quote End ---
