18 years agoHow can I get data from Altera Triple Speed Ethernet (TSE) MAC through Avalon bus?
I know the simple answer will be use NisoII... But in my situation is ..I cannot use NisoII or any other soft/hard core processor (actually is..I am not able to use any asm/c ..whatever comput...
17 years agohi, i have a stratix 2 GX too, i would like to run in MII mode to test under uclinux, i have some problem too, i can see the rx led blinking but no the tx led. i 've connected the tx_clk to pin F28 (i think is 25 MHz provided by the PHY) and rx_clk to pin M27 (also provided by the PHY).
