18 years agoHow can I get data from Altera Triple Speed Ethernet (TSE) MAC through Avalon bus?
I know the simple answer will be use NisoII... But in my situation is ..I cannot use NisoII or any other soft/hard core processor (actually is..I am not able to use any asm/c ..whatever comput...
18 years agoHi,
I am currently trying to configure TSE MAC core on Stratix II GX board. Even I have similar confusions with gtx_clk and tx_clk. If you have any further information, please let me know. Thanks and Regards Praveen --- Quote Start --- Hi! Thanks for reply: General concerns: - HW pin mapping, the names of the TSE "signals" and the pin mapping of the PCIe dev. board is not 1 to 1. For example I have mapped GM_RX_DV to PIN_E28 which is enet_rx_dv in the board ref. manual. - The ref. clk of 125MHz in TSE manual is connected to gtx_clk and to tx_clk. Im not sure if I should map it to pin b33 which is enet_gtx_clk or if I can use the same as rx_clk i.e. enet_rx_clk pin M27 (actually signal is "connected" in VHDL i.e. tx_clk <= rx_clk) - THe rest of my system uses PIN_A20 for clk, I believe it's around 150MHz. Im not sure if it's ok, but I guess it's a different clock domain. 1. I set the mac in the following way constant mac: std_logic_vector(47 downto 0) := X"861D33B91900"; ... mm_writedata <=mac(31 downto 0); ... mm_writedata(15 downto 0) <=mac(47 downto 32); The Command-Config reg: constant tx_ena: integer := 0; constant rx_ena: integer := 1; constant promise_en: integer := 4; constant tx_addr_ins: integer := 9; constant rx_err_disc: integer := 26; ... cc_reg(tx_ena) <='1'; cc_reg(rx_ena) <='1'; cc_reg(promise_en) <='1'; cc_reg(tx_addr_ins) <='1'; cc_reg(rx_err_disc) <='1'; ... write the next cycle. I'm not sure I understand "Tight the sw reset bit to a LED" I guess i set it with a write <='1', writedata<=... towards avalon-mm then I need to read it once and check if it is still "1". If it is the reset has not "passed" then something is wrong or? I have set set_1000<='1'; which I guess hard codes the GBit "way". After a PHY reset the 1000 led is shown on the card so I guess the PHY is aligned but I'm not sure what will happend if I connect a 10/100 device. If needed I can send you my small "project" if it is easier for you too check but I will try to have a look at the reset bit and the stat. regs. I attached the pin file for review. --- Quote End ---
