15 years agoHow can I find some free IP of i2c uart and spi etc.
as the title
15 years ago --- Quote Start --- Basic UART and SPI are included for free with Quartus. --- Quote End --- Only as SOPC components (NIOS II peripherals). Although you are basically able to extract the code and use it for native HDL designs, it's far from being convenient. Opencores is always a place to look for, but the UART and SPI IP tends to be more complex then needed for basic functionality. Simple UART designs have been published at Altera forum before. SPI in a native HDL design isn't much more than a shift register. Data formats and clock speeds as well as parallel data connectivity are changing for each implementation, so it's probably best to write it from the scratch, tailored for the respective application. P.S.: A simple uart example http://www.alteraforum.com/forum/showthread.php?t=5184
