17 years agoHelp with altera FFT
hello; what i want to do is to get spectrum of an sinusoidal signal using the altera fft core i have generated a v8 fft with the following setting: fft point : 64 (to start with) archi...
17 years ago --- Quote Start --- What are the I and Q in your equation sqrt(I^2 + Q^2)? Are they the real and imaginary values from the FFT source_real and source_imag? --- Quote End --- yes, I & Q are the special names in communications given to the two channels representing in effect a complex signal, I = inphase, Q=Qudrature. --- Quote Start --- Do I do the scaling with source_exp on both the source_real AND source_imag? --- Quote End --- you need to scale according to the way altera have done their IP. I believe it is the output of fft that must be scaled...ofcourse, check the IP data sheet. --- Quote Start --- Also do I do the scaling before or after doing the sqrt(I^2 + Q^2)? --- Quote End --- In normal computation such as matlab you don't need any scaling. Altera simply left that for you. So for your hardware results yes do scaling first. I checked the matlab output and it looks like your results: your result .....................matlab fft real = zeros .....................same imag(0) = 0 .....................same imag(1) = -8192 ..............-1048576 imag(63) = +8192 ............+1048576 imag(others) = 0 ..............same If you now multiply 8192 by 2^7 you get matlab result. Your problem now is this: your final output value needs far more bits than just 16 signed so you need to divide down by truncation to a max of 32767 or less. Your other case of having one sample just above zero ...etc. No don't do that. By doing that you are no longer having a proper sine in the sense of orthogonality in a complex vector.
