17 years agoHelp with altera FFT
hello; what i want to do is to get spectrum of an sinusoidal signal using the altera fft core i have generated a v8 fft with the following setting: fft point : 64 (to start with) archi...
17 years agoI changed the FFT to a 256-point burst architecture with the inputs coming from a ROM. When the ROM content is from a digitized 1000Hz analog sine wave, I get two peaks with sidelobes (is that what you call them?). However, when I change the ROM data to numbers generated by the equation
ROM_data = sin(2*1000*pi*[0:255]/256) The FFT output is all zeros, and even the exponent is all zeros. What happened?
