15 years agoHelp with Altera DE2-115 8" LCD
when running the demonstrations for the tpad i run into problems such as node "c0" is missing source file. I was wondering if anyone can help me better understand how to run the tpad demonstrations o...
14 years agoI don't know about tpad. But the error you got is apparently related to the pll where node "c0" is the pll output. I came across a similar error when the pll used had the "altpll" name in sopc. Just change the name a bit (by adding one or two characters) and recompile.
Hope this fixed your problem.
