17 years agoHelp requested with FIR/IIR filters please
Hi, I am presently using the FIR filter ip wizard in my project and have found that I am using a lot of resources and power to acheive my requirements. I have been told that IIR filters are mu...
17 years ago --- Quote Start --- Hi, My sample rate is 200MSPS (fixed) , and I require the following filters: 500kHz 1MHz 2MHz 3MHz 4MHz 5MHz 7.5MHz 10MHz --- Quote End --- Your filter(s) spec is not clear: First what is your filter input frequency content and input sampling rate? second: do you mean 10MHz,7.5MHz etc. as cutoff points or required sampling frequency? Do you mean one variable filter or multiband filter or several filters each with its cutoff? Third: are you concerned about non-linear phase?
