15 years agoHelp please - Unable to Compile 32K FFT
Hi all , please advise me on below... I am following the tutorial from Altera website on 32k FFT point Design.... I have configure the FFT megacore and then trying to compile it... bu...
15 years agoDid you follow the steps suggested on the Altera website?
FFT 32K Point Design Example v1.0.0 README File
This readme file for the Fast Fourier Transform (FFT) 32K Point Design contains
information about the design example posted on the Altera Support website:
http://www.altera.com/support/examples/exm-index.html
Ensure that you have read the information on the design example web page
before using the example.
This readme file contains the following sections:
o Package Contents
o Tool Requirements
o Quartus II Compilation
o ModelSim Simulation Models
o MATLAB Models
o Core Directory Names
o Release History
o Design Examples Disclaimer
o Contacting Altera
Package Contents
Fast Fourier Transform (FFT) 32K Point Design Example v1.0.0
Design files in the zip download include:
� fft_32K.v - Top level design file implementing the 32-K point FFT
� parse_fft_input.v - Reorders the input sample into even and odd samples to feed into the
two smaller 16K point FFT blocks
� fft_small.v - Wrapper file generated by the FFT IP MegaCore. The core is configured to
implement transform length of 16K, and it uses the streaming I/O data flow structure.
� combine_fft.v - Recombines the output of the individual 16K point FFT blocks using the
appropriate twiddle factors
� fft_32K_streaming_tb.v - Testbench for RTL simulation
� fft_32K_streaming_vo_msim.tcl - TCL script to automate the RTL simulation process in ModelSim
� fft_32K_tb.m - MATLAB model to verify the RTL simulation results
Tool Requirements
This design example requires the following software package:
o Quartus II 5.0 or later
o FFT MegaCore v2.1.3
o ModelSim version 6.0 or later
Please contact your local sales representative if you do not have one of these
software tools.
To run the compilation for the Viterbi Decoder Node Synchronization project in Quartus II,
perform the following steps:
1. Open Quartus II project: File -> Open Project -> ..\Quartus_II\fft_32K.qpf
2. Specify the FFT MegaCore Function user library: Assignments -> Settings -> Category (User Libraries)
Browse to the <path>\fft-v2.1.3\lib in the Library name box.
3. Review FFT MegaCore parameters using IP Toolbench: Tools -> MegaWizard Plug-in Manager
Select "Edit an existing custom megafunction variation" and choose the FFT IP block:
../source/fft_small.v
You can review the parameters by clicking on the "Parameterize" button in IP Toolbench.
4. Regenerate the FFT MegaCore files by clicking on the "Generate" button in IP Toolbench.
5. You are ready to compile the design in Quartus II: Processing -> Start Compilation
To get more details on the FFT IP MegaCore, refer to the FFT MegaCore Function User Guide
located at:
http://www.altera.com/literature/ug/ug_fft.pdf
In IP Toolbench, the option to generate Verilog/VHDL simulation model is enabled in the "Set Up Simulation" window.
The steps to generate the simulation models from IP Toolbench are highlighted in the previous section:
"Quartus II Compilation". We will be using the Verilog IP functional simulation model to verify the design in ModelSim.
To run the functional simulation for the FFT 32K Point design using ModelSim, perform the following steps:
1. In ModelSim, change the directory to the ..\altera\design_example\FFT_32K\source directory: File -> Change Directory
2. Open the fft_32K_streaming_vo_msim.tcl file and update the path to the megacore_lib_dir setting to where the FFT IP is installed.
3. Source the TCL script file: Tools -> Execute Macro -> fft_32K_streaming_vo_msim.tcl
The TCL script sets up the ModelSim project, compiles the appropriate libraries and design files,
runs the simulation, and displays the result in the waveform editor.
To get more details on the IP Functional Simulation Models, refer to the Altera white paper titled
"Using IP Functional Simulation Models to Verify Your System Design White Paper" located at:
http://www.altera.com/literature/wp/wp_simgen.pdf
MATLAB Models
To verify the RTL simulation results are correct, you can compare them with the results from the provided
MATLAB models found in the ..\altera\design_example\FFT_32K\MATLAB directory
To run the MATLAB models, perform the following steps:
1. In MATLAB, change the directory to the ..\altera\design_example\FFT_32K\MATLAB directory
2. To generate the twiddle factors for the 32K point FFT (twiddle precision is set to 16 bits),
type the following command at the MATLAB workspace:
>> = gen_twiddle_factor(32768, 16);
3. To run the MATLAB model, type the following command in the MATLAB workspace:
>> fft_32K_tb
If the ModelSim RTL simulation results match the results from the MATLAB models, it displays the following message:
"Simulation passes - Results Match". Otherwise, it displays the following error message:
"Simulation fails - Results Mismatch".
The default directory for your design example design is c:\altera\design_examples\fft_32K,
but you can specify an alternative directory.
