16 years agohelp me with the fft ip core
I am doing a project on OFDM system which uses the FFT IP CORE, I use the ip core to do a 128 pionts transform . During the process,I met some problems which I will describe as follows: Firstly,...
16 years agothe differences between the both waveforms is the souce_sop and source_eop,in the stp file,the souce_sop and source_eop can't coincide with the output data.they are not the starting and the ending or the output data of the ip core.
i hope you can help me .thank you
