16 years agohelp me with the fft ip core
I am doing a project on OFDM system which uses the FFT IP CORE, I use the ip core to do a 128 pionts transform . During the process,I met some problems which I will describe as follows: Firstly,...
16 years agocan you highlight where you are seeing the problem in the stp versus test bench?
