HDMI IP -> DRMI (Dynamic Range Mastering InfoFrame) -> how to derive?
In the HDMI Sink, the DRMI packets are mapped to the Address 0x88 of the Auxiliary Packet Memory Map:
But, how can I send the DRMI packets through the HDMI source? What's port should be used?
Thank you!
You are referring to the Design Example for Arria 10, but I'm working with the Cyclone-10.
Instructions for Cyclone 10 DRMI Filtering are different:
but they are not compatible with the generated code...
The User Guide for Arria 10, which you are referring to, is compatible to the generated code, which I have in my project...
Anyway, I'll set the multiplexer_in0_valid signal to '0' according to your recommendation and let you know whether it works.
- amildm
Contributor
I'm going to test the proposed configuration on the board till end of the week, so meanwhile please don't close the case, thanks!
- ZH_Intel
Hi amildm,
Thank you for the update.
>Should anything else be changed in the RTL in order to pass through the original DRMI frames with
>the original HDR metadata?
I have check with our internal team on this.
You may need to set multiplexer_in0_valid of the avalon_st_multiplexer instance in the altera_hdmi_aux_hdr.v file to 1'b0 to prevent the Auxiliary Packet Generator from forming and inserting additional HDR InfoFrame into the TX Auxiliary stream.
You may refer to below link for more information:
HDMI Intel® FPGA IP Design Example User Guide - Disabling HDR Insertion and Filtering
ZulsyafiqH_Intel
- amildm
Contributor
- amildm
Contributor
I've checked the modified design on the board - it works! Thanks a lot for your support, please close the case for now ...
- ZH_Intel
Hi amildm,
Yes, you are correct, we have already issue a fix to update the design example user guide.
The update is scheduled to be fixed in the next release of the HDMI Intel® Cyclone 10 GX FGPA IP Design Example User Guide.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
ZulsyafiqH_Intel
