11 years agoHDL Import [state machine in VHDL]
Hi everyone,
I designed a state machine in VHDL and I would like to incorporate it to my Simulink + DSP Builder Model. I'm using HDL Import, however upon pressing Compile button I get the error message shown bellow. Same happens when I try to compile the whole Quartus project. State machine VHDL is attached to this message. I would appreciate any hints on how to solve this problem. Best regards, Oz --- Quote Start --- Generating Simulink model........ Info: ******************************************************************* Info: Running Quartus II 64-Bit Analysis & Synthesis Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Full Version Info: Copyright (C) 1991-2013 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, Altera MegaCore Function License Info: Agreement, or other applicable license agreement, including, Info: without limitation, that your use is for the sole purpose of Info: programming logic devices manufactured by Altera and sold by Info: Altera or its authorized distributors. Please refer to the Info: applicable agreement for further details. Info: Processing started: Sat Mar 28 15:03:10 2015 Info: Command: quartus_map suballoc --source=../../suballoc/suballoc.vhd --simgen --simgen_parameter=SIMGEN_C_NETLIST=ON,SIMGEN_OPTIMIZATION=ALL,SIMGEN_PRESERVE_PORT_ORDER=ON Info (20029): Only one processor detected - disabling parallel compilation Info (12021): Found 2 design units, including 1 entities, in source file /primjeri/suballoc/suballoc.vhd Info (12022): Found design unit 1: suballoc-behavioral Info (12023): Found entity 1: suballoc Info (12127): Elaborating entity "suballoc" for the top level hierarchy Info (281010): Generating sgate simulator netlist using Simgen SIMGEN_PROGRESS Start of Model generation -- 0% complete SIMGEN_PROGRESS Phase 1 : Internal Objects created -- 25% complete SIMGEN_PROGRESS Phase 2 : Connections between internal objects made -- 60% complete SIMGEN_PROGRESS Phase 3 : Netlist generated -- 100% complete Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 5 to 5 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 5 to 5 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 5 to 5 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 4 to 4 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 4 to 4 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 4 to 4 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 3 to 3 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 3 to 3 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 3 to 3 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 2 to 2 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 2 to 2 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 2 to 2 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 1 to 1 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 1 to 1 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 1 to 1 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 0 to 0 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 0 to 0 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 0 to 0 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned. Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 18 errors, 0 warnings Error: Peak virtual memory: 519 megabytes Error: Processing ended: Sat Mar 28 15:03:12 2015 Error: Elapsed time: 00:00:02 Error: Total CPU time (on all processors): 00:00:02 Error: Quartus II Analysis & Synthesis was unsuccessful --- Quote End ---2 Replies
The source compiles OK with Quartus II 14.1
However the following code is a bit odd to read
and most would write it like this:process(clk_in, init_in, counter) begin if (rising_edge(clk_in) and init_in = '1') then if (counter = 63) then counter <= 0; -- resets counter when it reaches 320 else counter <= counter + 1; end if; elsif (rising_edge(clk_in) and init_in = '0') then counter <= 0; -- if "init_in" is set to 0, counter resets, as well as "start_tx_out" end if; end process;
Both ways seem to generate the same result, though.process(clk_in) begin if rising_edge(clk_in) then if (init_in = '1') then if (counter = 63) then counter <= 0; -- resets counter when it reaches 320 else counter <= counter + 1; end if; else counter <= 0; -- if "init_in" is set to 0, counter resets, as well as "start_tx_out" end if ; end if; end process; - Altera_Forum
Thank you for the comment and suggestions. The code looks much better.
I can actually compile original code in Quartus as well (no errors/warnings). The problem is importing this code into Simulink model with DSP Builder.
