17 years agoHDL Import, License Problem
Hello, I'm new to using dsp builder. I recently got a proof of concept up and running in which i simply connect one input pin to one output pin through a delay. This works no problem. I ...
17 years agoPerhaps your HDL utilizes some megafunctions that aren't supported by the HDL import function... (although not sure what error msg that would give you)... check reference manual for specifics...
