17 years agoHDL import - Multiple clock error
Hi, I was trying to convert the DE2 i2sound example (found in the DE2 demonstrations) to a DSP builder model file using HDL import technique. But i'm having a problem with multiple clocks ( 2 inte...
17 years ago --- Quote Start --- Hi, I was trying to convert the DE2 i2sound example (found in the DE2 demonstrations) to a DSP builder model file using HDL import technique. But i'm having a problem with multiple clocks ( 2 internally derived clock). I can not understand what in wrong in here. I've attached the files. Please help. thanks. Omee --- Quote End --- Hi, I try to run your project. I found out that the port list of your i2c_first.v does not fit to the component defintion. I have the corrected project attached. Kind regards GPK
