15 years agoHD-SDI another methord?
i wanna realize HD-SDI on the CYCLONE series which don't support HD-SDI Megacore, is there any metnord can help me?:)
15 years agoYou need to oversample data at least 5/4*clk speed like it is in SD-SDI non-transceiver mode. The line is 270MHz and oversample clocks are 337.5MHz and 337.5MHz+90deg.
HD-SDI has 1.485Gbps link, so the speed is much much higher. Do the math, what oversample speed do You need and You'll see thats its impossible in any ways. I even had problems with SD-SDI internal clocking...
