18 years agohave error in DSP builder when I use signal compiler
when i try to compile singen demo by signal compiler.The error message appears: Error: Failed to create Quartus II project singen in directory c:\altera\72\quartus\dsp_builder\DesignExamples\Tu...
15 years agoHi wronghorizon and jjcannon,
I have tried both of your suggestions. I still have the error: "Error: Failed to create Quartus II project FIRFilter in directory D:\altera\11.0\quartus\dsp_builder\Filter and Data Synchronization\FIRFilter_dspbuilder. Error: Error during compilation: Failed to update Quartus II project settings" when I try to compile with Signal Compiler. Do you have any other suggestions? To nguyenthehoang, Did you ever find a solution to this problem? Thank you all, rushale
