18 years agohave error in DSP builder when I use signal compiler
when i try to compile singen demo by signal compiler.The error message appears: Error: Failed to create Quartus II project singen in directory c:\altera\72\quartus\dsp_builder\DesignExamples\Tu...
18 years agoRight check environment variable and matlab path...
Also possibly delete the IP cache folder (the .altera.quartus folder under C:\Document and Settings\<your user name>\)... sometimes it gets corrupted and causes problems...
