18 years agohave error in DSP builder when I use signal compiler
when i try to compile singen demo by signal compiler.The error message appears: Error: Failed to create Quartus II project singen in directory c:\altera\72\quartus\dsp_builder\DesignExamples\Tu...
18 years agoThanks for caring. Do you mean i should check environment variable? :) .I am sure that all required environment variables are already set correctly.
