ASey's avatar
ASey
7 years ago
GMII interfaec for GigaE in LLE + Native PHY IP.
Hello guys,
I want to configure GigE using LLE IP and native PHY on cyclone 10gx EVB. Gmii_rx_d [8] on the MAC side is connected to rx_parallel_data [8] on native PHY. However, gmii_rx_dv [1] does not know which signal from PHY should be connected.
Usually, the IP is the gmii interface in PHY, but the native PHY does not
I do not know if I made the wrong setting.
Please ask for help if you know.
One mere thing is gmii_tx_en.
Thank you.
  • ASey's avatar
    ASey
    In addition,
    Development environment : Quartus 18.0 pro / LLE ip + Native PHY ip​ / qsys
    ​case : 10g interface [ parallel data & control ] <=>[gmii]
    wire [7:0] xgmii_tx_control;
    wire [63:0] xgmii_tx_data;
    wire [71:0] xgmii_tx;
    wire [7:0] xgmii_rx_control;
    wire [63:0] xgmii_rx_data;
    wire [71:0] xgmii_rx;
    assign xgmii_tx_data = {
    xgmii_tx[70:63],
    xgmii_tx[61:54],
    xgmii_tx[52:45],
    xgmii_tx[43:36],
    xgmii_tx[34:27],
    xgmii_tx[25:18],
    xgmii_tx[16:9],
    xgmii_tx[7:0]
    assign xgmii_tx_control = {
    xgmii_tx[71],
    xgmii_tx[62],
    xgmii_tx[53],
    xgmii_tx[44],
    xgmii_tx[35],
    xgmii_tx[26],
    xgmii_tx[17],
    xgmii_tx[8]
    assign xgmii_rx = {
    xgmii_rx_control[7], xgmii_rx_data[63:56],
    xgmii_rx_control[6], xgmii_rx_data[55:48],
    xgmii_rx_control[5], xgmii_rx_data[47:40],
    xgmii_rx_control[4], xgmii_rx_data[39:32],
    xgmii_rx_control[3], xgmii_rx_data[31:24],
    xgmii_rx_control[2], xgmii_rx_data[23:16],
    xgmii_rx_control[1], xgmii_rx_data[15:8],
    xgmii_rx_control[0], xgmii_rx_data[7:0]};
    if i had to make 1g.......​ when phy to mac (rx) , mac to phy (tx)
    rx_gmii_d
    rx_ gmii_dv
    rx_gmii_err
    tx_gmii_d
    tx_gmii_en
    tx_gmii_err
