Generic Serial Flash Interface for single SPI - how to connect MISO, MOSI?
I also have the same question. The Generic Serial Flash Interface Intel FPGA IP simply shows a 4-bit QSPI data line. There is no instruction in the user guide (https://www.intel.com/content/www/us/en/docs/programmable/683419/24-1-20-2-5/user-guide.html) for how to set up single mode! Are we supposed to guess and check where the MOSI & MISO lines go?
Come on Intel/Altera! 5 years since the original post and still no answer?? Disappointing.
- FvM1 year ago
the answer is in any QSPI flash datasheet of your choice. Flash SPI access always starts in single mode, therefore they have a fixed mapping of MOSI (flash DI) and MISO (flash DI) to IO[3:0] lines. You'd know if you read any. DI is IO0, DO IO1. The assignment should be fixed in a JEDEC standard, I didn't check because it's obvious for me.Anyway I agree that the question could have been answered clearly from the start.
