dsun01's avatar
dsun01
4 years ago
fundamental question about Jesd204b II
Dear Intel Support/Expert, I created a Jesd204b IP with the following parameters. in main page, Device Family: Arria10, "both base and phy", "Receiver", subclass "1", Data rate" 6144Mbps. "enab...
  • skbeh's avatar
    4 years ago
    Hi Havid
    The timing reference clock for the JESD204B IP core (txlink_clk, rxlink_clk) runs at data rate/40 because the IP core operates in a 32-bit data bus architecture after 8B/10B encoding.
    So far I have not seen the use case of data rate/80.
